Previous in Forum: Centrifugal Pump Assembly and Performance Parameters   Next in Forum: Pressure Reducing Station - Operating Duration
Absolute Filtration and Norminal Filtration
11/19/2009 9:51 PM
I am reading API 618 co-related with API 614 and found interesting chapters for filter requirement.
I do understanding the beta ratio. For me and all subscriber's understanding, I attached nice description about beta ratio from one maker's web-site, reformed by MS-Word.
What I am still wondering is ...
Is surface filtration absolute filtration as shown in the file and is depth filtration norminal filtration also? (this is my understanding after reading this)
Since depending on filter element micro-structure, one filter will maintain the beta ratio when DP reaches its maximum allowable value while another filter will not maintain the beta ratio, I do understand in such way.
Can anyone advise me this point?
(By the way, How can I attach this word file???)
Pathfinder Tags: filter efficiency
Re: Absolute & Norminal Filtration
11/19/2009 9:54 PM
Forgive me dear advisors,
I think now that attaching file in CR4 forum is not possible.
here you can click the web site I mentioned. No intentional advertisement.
Just sharing~!!!
http://www.oilanalysis.com/article_detail.asp?articleid=564
11/19/2009 10:55 PM
Not sure about your question, but to confuse the matter just a bit look here
Caution must be exercised when using beta ratios to compare filters because they do not take into account actual operating conditions such as flow surges and changes in temperature.
A filter's beta ratio also does not give any indication of its dirt-holding capacity, the total amount of contaminant that can be trapped by the filter throughout its life, nor does it account for its stability or performance over time.
Nevertheless, beta ratios are an effective way of gauging the expected performance of a filter.
11/20/2009 12:40 PM
Good answer,
I like to add it does not take into consideration of the filter media clean-ability after fouling (due to the filter media construction).
p911
Register to Reply 3 comments
Anonymous Poster (1); phoenix911 (1); yeonhoyu (1)
