Previous in Forum: motor controller   Next in Forum: Inability to Weld
AC or DC field creation
01/10/2007 10:53 AM
What's the best way to create a 16 K gauss field in a cavity of 6"X 6"X 1.5". ???
Re: AC or DC field creation
01/11/2007 4:38 AM
  • Use NOSS (Non-grain Orientated Silicon Steel) core that has 6"x6" cross-section, with relative permeability more than 3000
  • Construct a U I I core with U section at bottom (say), then each I section would be on top left and top right of the U section
  • Arrange spacing of 1" between I-sections, to provide air-gap
  • Your winding should be wound / excited to 32000AmpTurns
  • By reducing the gap length to 0.1", you would only need about 3200AmpTurns
  • Good luck!!??
NeilJ
Good Answers: 109
01/11/2007 2:49 PM
Hi,
you can do this for some 10 to 100 millisecondes by discharging a heavy and costly bank of power capacitors through a coil that has to carry 1 to 2 kiloamperes per mm length, so at 1.5" it would be 37 to 74 kiloamp x turns. exact value depending on stray fields.
If you want to magnetise something that is inside then let the current run for some time until the eddy current that is excited in any electrically conducting part is damped out.
Take an ignitron valve for switching.
This is suitable only for pulse operation and is typically used in magnetising permanent magnets (with much higher currents and much smaller volumes.)
Or you take a superconductiong coil.
Or you make a permanent magnet construction: difficult in assembly and difficult in holding far enough the loose iron parts that may be attracted and damage everything with high impact.
Will cost between 20 and 50K$.
Consulting available at www.uni-kl.de/FWT (english or german or french)
RHABE
01/11/2007 3:25 PM
Doubt whether you could get the level of current required to flow in a pulsed system due to the high inductance. Probably best to operate at DC...
Overall core size would be about 600mm square, and with 1 to 2mm diam wire, you could squeeze enough windings on. A linear power supply giving out 5 to 10amps should be good.
Estimate lower cost than $10k
See us at: www.suretech.co.za
NeilJ
Register to Reply 3 comments
