Previous in Forum: AC or DC field creation   Next in Forum: Current Transformer
9 comments
Inability to Weld
01/10/2007 11:10 AM
There is a system in our plant i.e., a dredging unit. The system contains an engine drive system. Initially the system is started via battery units and they usually stay intact even when the engine is running. The problem is you can not weld since the earthing is common for the engine and a welding set and more so the dredge is in the midst of the lake which is full of water. So what can I do to achieve the ability to weld while the engine is running?
Pathfinder Tags: engine Welding
Good Answers: 120
Re: Inability to Weld
01/10/2007 10:52 PM
use oxy-acetylene welding
Per Ardua Ad Astra
01/10/2007 11:02 PM
if it is a diesel engine then once the engine is running you can disconnect the batteries and alternator leads and do the electric arc welding. no issues. otherwise you can use oxy acetylene welding.
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
01/10/2007 11:11 PM
Isolate the welder case/unit, and weld. Unless you are across the battery, there will be no crossfeed, either polarity. The engine is probably deisel, but the batteries probably operate fuel pumps, instrumention, etc. If you're worried, use an AC welder. And make sure you insulate the person doing the welding.
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
01/11/2007 7:28 AM
ATTACH THE GROUND LEAD OF THE WELDER AS CLOSE TO THE POINT OF THE WELD AS POSSIBLE
Good Answers: 247
01/11/2007 4:39 PM
I'll second this -- it works fine.
Good Answers: 114
01/11/2007 2:13 PM
Noscifi & guest have it right.
the path between the ground & the actual welding are what matters. I've welded on plenty of equipment with sensitive electronics [while running].
Make sure you have a clean well connected ground.
The frame of the welder shouldn't be touching the frame of the equipment [ to be welded ] in a way that would provide a possible ground path through any sensitive sensors or controls.
01/16/2007 12:40 AM
15jan07
Question:
1.)what are you welding? carbon steel, stainless steel, or aluminum?
2.)describe the "weld set"... what welder are you using?
3.)earthing... can you describe the "earthing", grounding of the weld set, "ground clamp"?
4.)where does the weld set get its power?
5.)Is the weld set connected to the engine other than by "earthing"
01/16/2007 2:09 AM
edited 15jan07
We should define a few words and describe a "weld set".
Welder= a person
weldor= a welding machine, power supply
weld set= a motor driven generator with one or more welding power source panels.
A weld set can be stated to have a motor, a generator, a power panel and a attached weldor.
So if you will answer the above questions then maybe I can help you remedy your inability to weld. like the old timer said, "if it ain't easy it ain't right"
01/16/2007 4:33 AM
edit: 17jan07
2.)describe the "weld set"... what weldor are you using?
Anonymous Poster (1); aurizon (1); Blink (1); Garthh (1); NoSciFi (1); sirius1845 (1); y eye (3)
