Previous in Forum: Power Consumption in Brine Electrolysis   Next in Forum: What's the Right Plastic for the Job?
Piping and resistance to corrosion and low pH?
11/22/2009 4:24 AM
Out of Asbestos cement, Re-inforced concrete & polymer pipes, which pipe is most susceptible to corrosion & low pH
Good Answers: 101
Re: ME
11/22/2009 6:55 AM
"which pipe is most susceptible to corrosion & low pH"
  1. Reinforced concrete, because both cement and steel are susceptible to attack from acids.
  2. Asbestos reinforced concrete, because the cement is susceptible to attack from acids but the asbestos is not.
  3. Polymer pipes are generally corrosion and acid resistant; they are susceptible to attack by organic solvents.
Re: Piping and resistance to corrosion and low pH?
11/23/2009 3:00 AM
The first two.
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
