Previous in Forum: Mobile Phone External Memory Card   Next in Forum: Push Pull Amplifier Circuit
MOSFET Questions
11/23/2009 5:50 AM
Hi guys, i wana know is there a difference between a p channel mosfet which has a positive Drain-source Voltage and a negative Drain-source Voltage. e.g -60V and 60V?
same goes to the Drain Current current,is there a difference between the positive and neagtive drain current?e.g 8A and -8A?
1 more thing i am looking for this MOSFET P CH, STP12OF06 or STN5PF02V but i cant get it around where i live, can anyone give me an alternative mosfet that can give me similar result?
Thanks for replying
Re: MOSFET
11/23/2009 8:28 AM
Hi. indeed. The drain and source are in effect bridged by an intrinisic diode that realistically prevents a positive drain source voltage of more than about a volt for P-ch MOSFETs, depending on the diode junction voltage drop.
As for drain-source current, if the gate is enhanced to turn the MOSFET on when the drain is positive with respect to the source, the channel can present a relatively easy current path in parallel with the intrinisic diode.
Good Answers: 18
Re: MOSFET Questions
11/23/2009 2:59 PM
Register to Reply 2 comments
