Previous in Forum: Spot Radiography & Full Radiography   Next in Forum: technician
Self-limiting in stresses
11/25/2009 2:21 AM
hello guys,
plz help me to understand the "self-limiting" concept in stresses.
primary stresses are not self-limiting whereas secondary stresses are self-limiting,
but, what is the meaning of self-limiting in stresses??
plz help us with example if you know.
thanks in advance
ashraf
Re: Self-limiting in stresses
11/25/2009 2:44 PM
A primary stress (internal pressure) can be analogous to a cantilever beam with a weight on the end. If you put too much weight on it, the beam will continue to bend until it breaks.
A secondary, self-limiting stress (thermal expansion) would be the same cantilever beam, but instead of imposing an over load - you would impose a set displacement/deflection. Such as - the end of the beam is to deflect 0.25". This would be analogous to a cantilever with a support under the opposite end with a 0.25" gap. The difference between the two is that the secondary, self-limiting stress will not "continue on" until failure - it will yield until the distance is taken up and then stop.
Good Answers: 74
11/25/2009 7:31 PM
The attached link discusses the difference between primary and secondary stress in connection with pressure vessel design.
Bruce
Register to Reply 2 comments
