Previous in Forum: Self-limiting in stresses   Next in Forum: hydro test condition
technician
11/25/2009 5:57 AM
Hi Guys
Can any one of u help me troubleshoot my vaccum pump,the motor runs but the pump is not working and i hope its the motor responsible of runing pump to do its job.
Thanks
Rgds
Daniel.
Re: technician
11/25/2009 7:18 AM
If your motor and belts are working, check the intake filter to insure that it is not stopped up. If those all check out OK then you may need to remove the Rotary Lobe Blower and inspect the inside of it. Watch out for very dusty material, it will kill a Rotary Lobe Blower. Hope this helps...
Re: technician
11/27/2009 8:23 AM
  • Check the coupling between motor and pump hasn't broken.
  • Check the non-return and pressure/vacuum relief valves on the system are working correctly.
  • Check the piping isn't blocked or broken.
If all else fails, read the Manual.
You might be interested in: Motor Test Equipment, Motor Repair Services
