Previous in Forum: Liquid Measurement   Next in Forum: Ms
12 comments
pushing water
11/25/2009 12:47 PM
how much air pressure would it take to move water up a two inch tube.
Good Answers: 101
Re: pushing water
11/25/2009 12:55 PM
Take the weight of water, find the area inside the tube, determine your volume of water you wish to move, factor in gravity to find the force needed to push up on the water to counteract gravity. you will need a force just greater than this force. Then, you'll at least have a start on enough information to ask the question in a way to get a good answer.
But you need to keep in mind, that water is heavier than air, the air will not "push or move" the water unless you create a piston/seal to keep them separated, or you'll just have a nice bubbling tube. So your/were going to need to know a bit more...
Re: pushing water
11/25/2009 1:31 PM
.433 PSI per foot of rise if you are pushing water.
Good Answers: 101
Re: pushing water
11/25/2009 6:27 PM
Just out of curiosity, what are your assumptions?
Re: pushing water
11/26/2009 8:41 AM
.433 PSI=1 foot of head.
You are correct when you say, "But you need to keep in mind, that water is heavier than air, the air will not "push or move" the water unless you create a piston/seal to keep them separated, or you'll just have a nice bubbling tube."
Happy Turkey Day.
HAPPY THANKSGIVING..........Here is a recipe I thought you would like for the holidays
Ingredients:
1 whole turkey
1 large lemon, cut into halves
salt and pepper to taste
butter or olive oil, whichever you prefer
Heat oven to 350 degrees
Rub butter or oil over the skin of the turkey until it is completely coated.
Sprinkle with salt and pepper and any other seasonings you prefer.
Take a knife and gently separate the skin from the breast meat;
Slide lemon halves under the skin with the peel side up, one on
each side. This way the juice from the lemon will release into the breasts.
Cover and bake for 30-45 minutes. Remove cover and continue
to roast until juices run clear, basting every 15-20 minutes.
If you've followed these steps correctly, your turkey should
look like the one in the picture.
Bon Appetit!
Re: pushing water
11/26/2009 10:22 AM
each side.....
This is an engineering forum, not a "breast implant one"
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Re: pushing water
11/27/2009 9:22 AM
Just a little lemon zest.
Re: pushing water
11/26/2009 4:02 AM
If you measure the pressure in inches of water, you don't need any maths.
The tube diameter is irrelevant, as the pressure is measured 'per square inch' .
E.G. 40 psi on a tube of 1inch section will exert 40pounds, but if you double the tube section, you have twice the weight of water, but you now have 80pounds of pressure as it was 40pounds per square inch and you have 2 square inches.
Re: pushing water
11/27/2009 7:58 AM
The pressure needed is the depth of the water using the expression
P=ρgh,
where P is the pressure, ρ the density (which varies with salinity and temperature), g the acceleration due to gravity (which planet is this pipe on?) and h the height of the water column above the air inlet point.
That's physics.
How fast the water moves up the tube is a function of the tube diameter, the flowrate of air into the tube, the viscosity of the liquid, the temperature, etc., etc.
That's process engineering.
  • Interestingly, there is a sewage treatment process involving the construction of a cylinder deep into the ground, fitted with a divider plate across its diameter almost to the bottom so as to make two interconnected shafts of semicircular cross-section. Sewage flows into one side of the cylinder. Air is blown in through a diffuser pipe near the bottom of the other side of the cylinder, and the air causes the sewage that side to rise. The pressure experienced at depth causes a high rate of take-up of oxygen from the air, and the time taken for an aliquot of sewage to get from the bottom of the cylinder to the top is an input into the reduction of biological and chemical oxygen demand in the sewage coming off the top of the second cylinder by the bugs present in the sewage. In one fell swoop one has processed a lot of sewage for a very small plant footprint!
Re: pushing water
11/27/2009 9:16 AM
Aliquot? is that anything like a brevquot...oh don't bother answering I'll look it up....
Re: pushing water
11/27/2009 9:34 AM
Maybe you want this?
http://www.fao.org/docrep/010/ah810e/AH810E07.htm
See 3.9 Air lift pumps
“Don’t worry, they usually don’t swim backwards.” Steve Irwin
Re: pushing water
11/27/2009 2:16 PM
I prefer the turkey talk,almost smell that aroma.......
Re: pushing water
11/27/2009 4:54 PM
Yep Leon and it seems you have to baste paste my link to get where I intended to send the ever curious Cat.
_Leon_ (1); indel (1); Kyzine (2); lyn (3); PWSlack (1); RVZ717 (2); user-deleted-1105 (2)
