I hope this is the correct forum.
I am running XP SP3 Professional. Recently I needed to switch off my computer and disconnect all wires whilst re decorating my room. When finished, I plugged everything back in and lo and behold, my Agfa Snapscan E50 scanner which is USB connected and previously working satisfactorily, responded with 'General SCSI error'. I tried different USB ports and all gave the same result. Disconnected sanner and removed software and re installed; same result - 'General SCSI error'.
I also have a laptop computer on which I installed the software and hardware. This computer is running XP SP3 Home Edition. After installation, I ran the software and the scanner works. I used a different USB cable for the laptop which was then used to connect to my PC. The PC reported the same error as previously.
Why should the same software being installed on 2 computers using the same hardware make one computer work and another not work? I have checked the registry and Properties which appear to be both the same.
Agfa stopped supporting this scanner several years ago and there appears to be forum on which I can as this question.
Any help or suggestions would be gratefully appreciated.
