Previous in Forum: General SCSI error on USB   Next in Forum: Visual Nastran 4D Software
Coordinates in Solidworks Drawings
12/01/2009 6:50 PM
I am trying to place or transfer a reference coordinate system into a solidworks drawing. I have tried using a hole table and notes. There must be a way to just transfer a coordinate system into the corner of a drawing. If anyone is aware of how to do this, please inform me. Thank you all so much, this will save me as I have already dedicated too much time to this endeavor.
Alex
Good Answers: 143
Re: coordinates in solidworks drawings
12/01/2009 6:56 PM
Are you asking about ordinate dimensions like you would use for sheet metal work? Just choose dimension, ordinate, place a Z point and away you go. You can't use the corner of the drawing, though. You have to use something that is referenced to the part.
Good Answers: 15
Re: Coordinates in Solidworks Drawings
12/02/2009 11:22 PM
Whats the data your trying to insert?
If its a 3D solid, you just have to reference it to the current part that is loaded
If your importing say a bunch of holes from a DXF file (I do this all the time, I convert a Excellon NC Drill file 2:4I-LZ into DXF thru a filter program)
Your model will need a reference location to place the "import" and a plane that it will be loaded on to.
"Insert -> DWG/DXF"
once the drawing is pulled in, you have to move its origin to the position on your model where you'd like that origin to reside, then next to rotate the "sketch" about that origin...
Tools -> Sketch Tools -> Modify
This will allow you to move the drawings origin to a "known" location, and rotate your drawing once that origin is locked into position
If the inserted file is the first part of the "part" your designing, then align the drawing with the part "Origin" and go from there.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
12/03/2009 3:43 AM
Please post a Template of your drawings Format to comment on / suggest.
Haajee (1); Snaketails (1); TVP45 (1)
