Previous in Forum: Rose bengal   Next in Forum: Choosing a Gasket Material for Austenitic Stainless Steel
8 comments
India - Member - Hello Friends
Glass Ceramics , Toughened glass, Float glass
11/29/2009 1:40 AM
can the experts in this field fwd to me the properties of these three on exposure to the temp of 300 deg C. Can Float glass be toughened if so how much heat it can with stand
Re: Glass Ceramics , Toughened glass, Float glass
11/29/2009 9:57 AM
I'd start with a search of each item and compare the results.
11/29/2009 1:57 PM
Thanks for your reply.
11/30/2009 3:06 AM
Good Answers: 19
11/29/2009 10:41 PM
toughened glass is float glass that has been toughened. best to look up the toughening (sometimes referred to as tempering) processs.
the heat that is able to be withstood depends on the rate at which heating/cooling is done and the thickness of the glass.
for instance, the heat soak test for toughened glass deliberately heats up the glass to a temperature below toughening temperature and then cools it rapidly to check for nickel sulphide inclusions which would make the glass break in service at a future date.
some good sites for this are:
-wiki (to begin with)
-http://www.glassfiles.com/ (you need to register for free to be able to access their free library but definitely worth it)
a good book on the subject is Michael Wiggington's Glass in Architecture
omw7
Good Answers: 74
11/30/2009 1:31 AM
Have a look at these english_technical_glass_handbook.pdf (application/pdf Object) guys. If they can't do it nobody can, Ky
The Twain Has Met
11/30/2009 3:07 AM
Thank U all for your Reply and Guidance.
11/30/2009 3:48 AM
Any glass can stand 300ºC. The problem is that they behave differently withthermal shock.
Glasses like borosil can stand sudden changes in temperature. Soda glass will break. If you application does not involve sudden changes in temperature any glass will work.
bioramani
11/30/2009 4:09 AM
Sir, Thank you for your reply.I would like to have your e-mail address for further contacts can you send it. My mail is : padasalanagesh@yahoo.co.in I am a Retired Mechatronics Engineer having 39 years of experience in manufacturing area, Quality Control, Maintenance(Mech/Elec./ Electronics) and in calibration of measuring devices. I would like develop Toughened Glass Plates for cooking hob/ stove with higher temp. with standing capcity. The glass available in the market is of float glass and i had the basic doubt about this glass's with standing capacity after Tempering/Toughening. Hence this question addressed to the experts. Regards P.S.Nagesh Chennai India
Register to Reply 8 comments
bioramani (1); ky (1); lyn (1); NageshPadasala (4); omw7 (1)
