Previous in Forum: Switches or Relays?   Next in Forum: Correlation Between Insulation Resistance, Polarity Index and Tan Delta?
CIRCUIT BREAKER
12/01/2009 1:42 AM
WHAT DETERMINES THE SIZE OF CIRCUIT BREAKERS IN A DOMESTIC HOME? YOU CAN SEND YOUR ANSWERS TO mulengac@mwsc.com.zm
Re: CIRCUIT BREAKER
12/01/2009 2:19 AM
Depends where the home is. Since you don't say, we can't help. If, on the outside chance you are in the USA, it would be the NEC. Tell me where you live and I'll tell you what NEC means.
Good Answers: 804
Re: CIRCUIT BREAKER
12/01/2009 3:38 AM
In general, Circuit Breakers protect the wire. So if a certain size of wire is used, the maximum CB size is dictated by the capacity of that wire.
Re: CIRCUIT BREAKER
12/01/2009 6:30 AM
British Standard 7671.
And please stop SHOUTING. Many readers consider it rather rude.
http://cr4.globalspec.com/thread/45769
Re: CIRCUIT BREAKER
12/02/2009 7:11 PM
Usually, it will be total average load needed for each domestic home. All these circuit breaker will be determine by your local power utility authorities charge-man, who has a valid charge-man license to design all the domestic home power supply requirement and will determine the size of the circuit breaker for all the domestic home base on the total average load
JRaef (1); lyn (1); PWSlack (1); Simon Wan (1)
You might be interested in: Circuit Breakers, Load Centers
