Previous in Forum: Switch Mode Power Supply   Next in Forum: Buchholz Relays
current operated relay
12/02/2009 1:17 AM
I have required current operated relay for using capacitor bank parallel with welding machine whenever welding machine flow current same time capacitor bank come across otherwise remain in off condition.
Re: current operated relay
12/02/2009 3:01 AM
Er, so, what's the question?
12/02/2009 6:05 AM
pls specify the clearly the question
12/02/2009 6:11 PM
Friend,
You can use Double pole Double throw switch, this is what your asking? do reply
Good Answers: 170
12/02/2009 11:49 PM
Yes! You can go for an Automatic Power Factor Correction Relay. But, please ensure that you go for dynamic compensation as welding machines are fast fluctuating loads. Compensation with contactors may not be effective.
electricalexpert65 (1); jhonson (1); luv123 (1); PWSlack (1)
