I have a need for a hydraulic motor system(s) to drive 3 machines that require an equivalent of 5 HP electrical motor each.
Is there a software tool or program that when given the specs of an electrical motor, e.g. hp, rpm, etc will generate a spec for an equivalent hydraulic moter system, including, pump ratings in PSI, gpm, volume of fluid, hose size, etc?
Also, can a single pump drive more than 1 hydraulic motor?
Thanks in advance all the help.
Ashraf
