Previous in Forum: How to Spec a Hydraulic Motor System   Next in Forum: API 650 Addenda and Unanchored Tanks
10 comments
Aluminum - Temperatures and Deformation
12/03/2009 11:21 PM
I have a requirement where aluminium is used in a oven Temp of 200 Degree C. I wanted to know whether the material will deform at this temperature.
Pathfinder Tags: Mechanical properties
Re: what Temp Aluminium can resist H13.
12/04/2009 5:55 AM
Deformation strain is related to the deformation stress.
http://en.wikipedia.org/wiki/Hooke%27s_Law
The characteristic changes shape with temperature. At the melting point, the shape reduces to a line at zero deformation stress.
http://en.wikipedia.org/wiki/Aluminium
Good Answers: 109
Re: Aluminum - Temperatures and Deformation
12/05/2009 2:33 AM
How much deformation per day at which stress?
RHABE
Good Answers: 68
12/05/2009 3:08 AM
Hi Mahendra,
Can you give a few more details about what grade of aluminum you want to use and its thickness. And what exactly are you wanting to use it for in an oven? Will it bell carrying a weight other than its own, like when you use it for a shelf? Or is it just for the box structure of the oven?
Good luck, and please get back to me.
12/05/2009 12:23 PM
Hi, It is Aliminium 6082, 508x406mm 12.7 mm thick, Well i dont have the information of whether there is any weight applied on the plate, I will collect the same from my customer. It is for testing purpose that is the information i have. I will get back once i have the details Thanks & Bye
Good Answers: 68
12/05/2009 6:38 PM
Hello Mhendra,
Really appreciate the reply post, thank you!
Sounds like you are dealing with a good strong piece of 'ally' there! Most I have seen and used is ¼" (~6 mm).
I will get back to you soon.
Good Answers: 68
12/06/2009 12:25 PM
Hello Mahendra,
I list below the detailed specs of the Aluminum you are using. the 6082.
Hope it helps. And any other questions you can pass on after the week end.
http://www.azom.com/Details.asp?ArticleID=2813
Good luck.
12/05/2009 12:00 PM
It does not. It can anneal though and lose some mechanical properties. Aluminum is routinely used for fry pans and other cookware that see much higher temperatures in routine use.
bioramani
12/06/2009 6:29 AM
Dear Mahendra ,
It depends on the temper designation of the material.
If the material is condition "O" which is soft it will not take the load.
I suggest you go for condition T4 solution treated or T6 Solutionised and Precipitate hardened- conditions under which the alloy has the maximum strength.
200 deg C is the Precipitation temperature of the alloy and hence will not loose its mechanical properties when exposed to this temperature.
Good Answers: 109
12/06/2009 6:36 AM
As the recommended ageing conditions range fro 170°C to 240°C, depending on alloy,
you will have very soon a considerable overageing with loss of strength.
So too it may not take the load.
Anything depends on how much load and resulting creep-velocity and on alloy and ageing conditions.
RHABE
12/06/2009 6:46 AM
Yes.
I agree with your observation considering the possibility of repeated exposure to this temperature.
Register to Reply 10 comments
babybear (3); bioramani (1); krishnan.ng (2); Mahendra Bhat (1); PWSlack (1); RHABE (2)
