Previous in Forum: Aluminum - Temperatures and Deformation   Next in Forum: One of Our Submarines ... (Is Missing)
India - Member - Rajasekar
API 650 Addenda and Unanchored Tanks
12/04/2009 1:30 AM
Please clarify API 650 Add 1 and Add 2 (11th Edition) revision the equation is correct or wrong
5.11.2 Unanchored Tanks API 650 11th Edition Add 2 Nov2009 Effective Date is May-2010
Unanchored tanks shall satisfy both of the following uplift criteria:
1. 0.6Mw + MPi < MDL /1.5
2. Mw + 0.4MPi < (MDL + MF)/2
where
MPi = moment about the shell-to-bottom joint from design internal pressure,.
Mw = overturning moment about the shell-to-bottom joint from horizontal plus vertical wind pressure,
MDL = moment about the shell-to-bottom joint from the weight of the shell and roof supported by the shell,
MF = moment about the shell-to-bottom joint from liquid weight.
The liquid weight (wL) is the weight of a band of liquid at the shell using a specific gravity of 0.7 and a height of one-half the design liquid height H. wL shall be the lesser of 0.90HD for USC units and 14.8HD for SI Units:.
In SI units:
WL = 59.tb x SQRT Fby.H (N/m)
But, Appendix E 6.2.1.1
Wa = 99.tb x SQRT. Fy.H Ge (N/m) < 201.1 HDGe in SI Units
based on the equations in appendix E i have calculated that for SI units it should be 141HD
Regards
Rajasekar
Re: API 650 Addenda and Unanchored Tanks
07/22/2011 12:01 AM
Your finding is correct .formulas in US unit is correct. I am using SI unit with corrected formulas
