Previous in Forum: Negative Load Flank Angle Threads   Next in Forum: P&ID Line Number
9 comments
Pneumatic Valves with Flow Diagram
12/05/2009 5:19 PM
hi...
this is sumitro.am working in a manufacturing plant as a maintenance engineer.i want some details about the 5/2 and 5/3 pneumatic valves with flow diagram.can somebody help me???
thank you...
Re: Pneumatic Valves with Flow Diagram
12/05/2009 10:39 PM
Try Google. If you're an engineer, it should be pretty easy to figure out the keywords ...
12/06/2009 3:25 PM
To Mikerho,
i tried google but i couldn't get any proper flow diagram thats why i am asking for help.if u want to help me then send me any link or something by which i get the exact conception about pneumatic valve.
thank you...
Indonesia - Member - Control & Instrumentation Engineering Fields - Control Engineering - Control & Instrumentation Engineering Fields - Electrical Engineering - Control & Instrumentation Engineering Fields - Electromechanical Engineering - Control & Instrumentation Engineering Fields - Instrumentation Engineering - Control & Instrumentation Engineering Fields - Systems Engineering - Control & Instrumentation
12/07/2009 12:22 AM
Hi Sumitro,
The 5/2 or 5/3 Pneumatic valves are showing the identical Soleniod Valve
5/2 means that the Solenoid valve has 5 ports and 2 positions, and
5/3 means that the Solenoid valve has 5 ports and 3 positions..
about the diaghram there are some samples drawing in pdf...
Regards,
SG
"Live for your next living"
12/07/2009 1:34 AM
1. Refer to Sperry-Vickers products catalogue; they are hydraulic-pneumatic makers.
Otherwise, What does that valve tag show ?
Well, the valve tag might already have that diagram you are looking for.
2. 5/2 = 5-way 2-position ?
3. 5/3 = 5-way 3-position ?
4. How is that pneumatic valve actuated ?
5. Manual-Operator ? Pilot-Activated ? Spring-Centred ?
6. Regards.
12/07/2009 9:42 AM
Flash Animation link for a 5/2 valve
http://www.mercuryindia.net/mercury/Main.swf
Click on VALVES
Click on Basic Working Animation.
Regards Woody
12/07/2009 12:28 PM
thank u......
12/07/2009 12:01 PM
Hi There Sumitro008,
If you tell me what your application is i will gladly help you, contact me at PROair Solutions
My name is Barry Le Roux
12/08/2009 8:30 AM
the pneumatic values with flow u wants theu orking can u say in which machine and the delivery status from that i can helpo u there for ur maintnance work.
03/18/2025 8:13 AM
Well, the manufacturer's name of these valves has been withheld from the forum, which is one problem. For information about the valves themselves this is the obvious direction, and an assumption is being made that there is at least a telephone available at the facility.
As far as the second problem, what the valves are supposed to be doing, there will be a Control Philosophy document to illustrate the principles involved in operating the [whatever] equipment in which these <...5/2 and 5/3 pneumatic valves...> are installed. Also, there will be as-commissioned records to hand, which may well include a schematic of the pneumatic installation in question. Those documents cannot be seen from here.
So, fundamentally, CR4 is the wrong place to look.
Register to Reply 9 comments
Anonymous Poster (3); Barry Le Roux (1); Mikerho (1); PWSlack (1); sumitro008 (1); Supr3633 (1); woodygb (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
