Previous in Forum: Selecting Gas Pipeline Instruments   Next in Forum: Cable Types
How to Automate Test and Measurement Equipment
12/07/2009 6:21 AM
Dear Sir,
This is Ravi .M (m_ravi1110@yahoo.com)
We have a list of test & measurement equipments for our testing activity,
Presently we are operating this instrument manualy and I need to convert to this as a automition system
Examper : I need to verifiy RF signal generator it's having Frequency rang from
10 MHz to 26.5 GHz and Amplitude rang -110dB to +13 dB
We will verifiy this RF signal generator using Spectrum analyzer with same rang with following below Procedure
1Connect the equipment as shown in Figure
2On the Signal Generator , Press
PRESET. Set the controls as follows:
CW frequency . . . . . . . . . . . . . . . . . . . 1.5 GHz
Power level . . . . . . . . . . . . . . . . . .. . −10 dBm
3On the spectrum analyzer, press PRESET. Set the controls as follows:
Center frequency. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 GHz
Span . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 MHz
4On the spectrum analyzer, press
RECALL, MORE 1 OF 2,FACTORY PRSEL PK.
5On the spectrum analyzer, press
PEAK SEARCH.
6Record the MKR frequency in Table 1-1 as the marker reading.
7Repeat steps 2 and 6 for all frequency listed in table 1-1
Frequency Accuracy Test
Input FrequencyMeasured Frequency
100MHz
1GHz
10GHz
13GHz
18GHz
22GHz
26GHz
Table 1.1
Re: Operating the T&M Equipment by Automation (PC to Instrument through GPIB)
12/07/2009 6:39 AM
Re: How to Automate Test and Measurement Equipment
12/08/2009 4:48 PM
I would use National Instrument's LabVIEW software to automate that test. They also have a SW package called Signal Express that is cheaper, and will do most of what you outlined.
07/18/2011 1:50 PM
Inspite of using those NI or other ready made tool, Can i create One flat form ?!!!!!!!!!!!!
Ex:- using Unix/C/C++/jave/dot net etc..................If it is possible Pls help me
07/18/2011 5:05 PM
Is the same person as RAVI 1110?
I have had extensive experience with signal generators and spectrum analyzers, but I am not a programmer. You can automate the process that you described using a PC and software such as Visual Basic. Excel can be programmed with VB as well, which can make reporting easier.
07/19/2011 6:46 AM
thanks for your response, yes i am same person as ravi1110......
I have idea about only SCPI command, How we can put it in excel & link to VB
If you have any Idea Pls.........tell me else Do you have any one small program(Eg Self cal of Agilent/E44XX series spectrum analyzer etc),
Pls do need full
Anonymous Poster (1); m_ravi1110 (1); PWSlack (1); WoodwardDL (2)
