Previous in Forum: Why is 230V Single-Phase?   Next in Forum: Power Cable Temperature
Non-Loosening Motor Connection Box
12/10/2009 11:03 AM
I'm looking for any technical information concerning "non loosening motor connection box" standard for
Good Answers: 804
Re: Non-Loosening Motor Connection Box
12/10/2009 4:16 PM
I'm having trouble figuring out what a "loosening motor connection box" would be, so a "non-loosening" one is even harder to grasp.
Assuming that English is not your native language, maybe you can describe your situation in more detail.
12/10/2009 11:59 PM
yes, you are right
I need non-loosening connection box information
12/11/2009 3:04 AM
The forum needs to understand the difference between a loosening connection box and a non-loosening one before a meaningful response can be given to this thread.
Good Answers: 61
12/11/2009 10:05 AM
I suspect you are referring to the IEC "e" standard for non-loosening terminal connections. They are designed for use in areas of high vibration, where standard screw terminals may work loose over time. See page 13 of the IEC/NEC Classification Comparator for more detail.
12/11/2009 10:25 AM
this is exactly what I mean,
Thank you indeed.
Now if your can lead me to more details how to specified to the motor manufacture
Norberto
JRaef (1); Norberto (2); pwr2thepeople (1); PWSlack (1)
