Previous in Forum: Research Octane Number (RON)   Next in Forum: SA-285 Grade C vs. ASTM A-36
22 comments
Wanted: The World's Strongest Microfiber
12/11/2009 11:36 AM
Does anyone know a source for a super high tensile fibre (monofilament or multifilament) that can be supplied in diameters of less than 30 micrometers? Tensile strength of greater than 2000MPa are required at a minimum
Thanks,
Eamon
Ebony
Good Answers: 42
Re: Strongest Micro Fibre in World
12/11/2009 11:38 AM
Check out for KEVLAR or ARAMID POLYMER based fibrous filaments.
Nature is so graceful and naked. Human possession is ridiculous.
12/11/2009 11:47 AM
Thanks, I have tried but I cant get a source that supplies them in a bundle diameter of less than 30 micrometers. I have also tried UHMWPE but again they come in larger diameter bundles.
Ebony
Good Answers: 15
12/14/2009 4:32 AM
Hello Eamon,
Many Dupont polymer scientists certainly have worked in this arena. I used some equipment that we purchased in Philadelphia in the late eighties. This equipment was custom built in Germany to spin UHMW filament.
We utilized some of the godets to draw UHMW to give very high strength ribbon. Our draw rates we comfortable at 10:1 but the material was brittle at higher ratios.
I made a simple rig to draw nylon fishing line to an extremely fine and super strong monofilament.
If you have exhausted your search of commercially available sources you may be able to produce it yourself in small batches.
If you need to have some design ideas I can share what I remember of the set-up I used. Using the basic necking principles that are evident when you draw a piece of nylon or propylene string in your hands or a common drinking straw.
I provided a finely controlled heating device with a small opening through which I passed the nylon fishing line. The heating device and small opening were not in direct contact with the line but provided a means to soften the line to create an initial necking effect. (The higher the heat the faster and thinner the filament necked).
Starting with a suitable diameter and length you could produce batch lengths with high draw ratios. You could readily produce lengths in the 30' region with a minimal investment in equipment.
The control of strength of the filament came from the fine tuning of the relative drawing force to orient the polymer in relation to the heat to initiate necking. Furthermore a tight control of the post necking heat affected zone to the cooled region allows for continuous drawing and orientation of the polymer.
Since this work, which was done a long time ago, I experienced how cathether tubing is produced using nitinol or shape memory metal. Using the principals employed in this industry I can imagine the capability to produce endless lengths of highly oriented fibre of specific diameter and strength. Call Dupont and ask them whose is doing work in this field presently using their Nomex and Kevlar fibres.
If you have any interest in exploring this further I could try to dig up leads for you.
Good Luck
I like 2 tinker-no, really!
12/14/2009 4:37 PM
Hi "2Tinker",
Thank you for your detailed and thought provoking response. I hadnt really considered drawing and orienting the fibres myself. As you describe it, I can clearly see how you would use temperature and draw force to get both size and strength optimised. It may be a real option if I get a base material that has the potential to deliver the strength I need.
I have already tried oriented PET fibres in diameters of 25 microns but it just doesnt have the strength. I have assumed that PET can achieve higher tensile strengths than Nylon and havent focused on Nylon because of this. Neither material is capable of strengths above 1GPa. If there is a grade of nylon that is a lot stronger than this when oriented then that may be interesting? I have assumed Nylon 11 to be the best in the family due to its ability to store orientations. They are widely used in angioplasty ballons (which are bi-axially oriented) for this reason.
My first step is to identify a material grade that has the potential. I may then circle back to you and take you up on your offer for some leads on the processing.
Thanks,
Eamon
Ebony
Good Answers: 68
12/14/2009 5:47 PM
Hi 2tinker,
GA to you Sir!
Take care.
Good Answers: 18
Re: Wanted: The World's Strongest Microfiber
12/11/2009 3:46 PM
Spider web
12/12/2009 3:54 PM
Specifically Black Widow spider Web. It was used for gun sights during WWII.
Good Answers: 213
12/11/2009 11:19 PM
Have a look at Spiderwire Fishing line...
12/11/2009 11:28 PM
What is the length of filament you require?
12/13/2009 9:16 AM
Hi Greg, I want a continuous fibre. It will be braided or knitted and the free end has to fit through a hole of 30 microns.
Eamon
Ebony
Good Answers: 68
12/13/2009 9:35 AM
Hi Eamon,
Is there any chance you can tell us what this fibre is for? Are you making a pair of gloves for a shrew or perhaps even a 'tootsie' warmer for a spider?
Have you thought of looking into sutures? I do not know if they have anything small and strong enough for you.
But then, I do not know and cannot think why you would or could use such tiny 'thread', which equates to ~5 human hairs thick?
Take care
12/13/2009 10:55 AM
I am using them as part of a device for treating patients with stroke. The device actually enters the brain through a tiny blood vessel. This is why the fibre needs to be very strong and very small.
Eamon
Ebony
Good Answers: 68
12/13/2009 11:20 AM
Hi Eamon,
I really appreciate your reply post to me thank you!
Is there a name for the procedure you do or plan?
Good luck.
12/13/2009 2:34 PM
We are still in development at this point... so I cant disclose much more :-)
Eamon
Ebony
Good Answers: 68
12/13/2009 4:28 PM
Hi Eamon,
No problems Eamon. What was the silk you were looking at, can you tell me that? Perhaps I have more time than you to find a supplier. Does it matter which Country the supplier is in?
Take care
12/14/2009 5:44 AM
Hi Babybear,
The silk was suggested by another responder to the forum thread. It is called Dragline Silk from Nephila Clavipes (a type of spider!). This fibre is interesting in that its tensile strenght is 2.9GPa (which would be great). However, it doesnt look like anyone has converted it into a commercially available fibre.
My preferred fibres for the application (at this moment) are UHMWPE or an Aramid if I could get them in the right sizes. However, I have not been able to find a supplier of high tenslie UHMWPE fibres that will make a bundle that is as small as I need. Obviously I am open to new material suggestions.
I have ruled out PET fibres and thermoplastic Nylon fibres as even in a highly oriented state, they just are not strong enough. Likewise with PEEK and PEN fibres.
The country of origin doesnt really matter provided the company has a defined process and a quality system.
Eamon
Ebony
12/14/2009 10:42 AM
"...I cannot think why you would use such tiny 'thread', which equates to ≈5 human hairs thick...?"
Are you equating yourself to a human, and stating that YOUR hairs are only about 6 microns in diameter?
http://hypertextbook.com/facts/1999/BrianLey.shtml
Silly bear !
Good Answers: 58
12/14/2009 11:07 AM
30 microns is about 1/5 the diameter of an average human hair, and about 1/8th the diameter of a rch.
Good Answers: 68
12/12/2009 12:40 AM
Good Answers: 58
12/12/2009 9:55 AM
You have requested is strong and small. If those are your only requirements, I suggest you consider dragline silk from Nephila clavipes which is considerably smaller than 30 microns and has a tensile strength of about 2.9 Gpa. A pencil diameter bundle of this fiber is strong enough to stop a large jet airliner in mid flight.
12/13/2009 1:59 PM
At 2.9GPa the tensile strength is certainly adequate. Having followed your lead I found a number of scientific articles on this silk fibre but no commercial supplier. Is it something that is commercially available?
Eamon
Ebony
Good Answers: 58
12/14/2009 8:23 AM
I am not aware of any commercial sources of spider silk. When the US military needed black widow silk for gun reticles, they had to develop their own sources. Spiders are not social animals and no one has figured out how to manage a spider farm. The diameter of dragline silk appears to be about 2-4 microns and is biocompatable. If it looks like a potential solution to your problem, I would seek out the entomology department at a university.
Register to Reply 22 comments
2tinker (1); Anonymous Poster (1); babybear (5); Bill (1); cwarner7_11 (1); dkwarner (1); Eamon B (7); Greg.Rudy (1); s.udhayamarthandan (1); welderman (3)
You might be interested in: Micrometers, Laser Micrometers, Depth Gages
