Previous in Forum: Current Sensing   Next in Forum: Meggering
11 comments
Replacing 7.2-V D Batteries
12/14/2009 2:07 PM
I have a portable air/gas instrument that uses 2-7.2v D batteries that need replacing. Factory batteries are too $. Can i use any rechargable batteries that add up to 14.4V ? I have limited space. Can I use less voltage or 9v style ?
New Zealand - Member - Kiwi
Good Answers: 29
Re: Replacing 7.2-V D Batteries
12/14/2009 2:12 PM
Should be quite safe to go to one 14.4V battery. Your equipment may well work down to 12V or so, but 9V is probably pushing your luck. The specifications for your instrument may well give a few more clues.
paulusgnome
12/16/2009 11:59 AM
thanks
12/16/2009 12:00 PM
thanks
Good Answers: 18
12/14/2009 2:41 PM
Do you mean that you have 2 _ 7.2 volt "D - sized" batteries? The classic "D" battery is of a particular size, and it is 1.5 volts (nominal).
The capacity of the batteries you have are important, as is the rate at which they discharge or can discharge. Rechargeable alkaline 9 volt batteries have very little capacity, and depending on the technology, may or may not deliver current at the rate of your original batteries.
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
12/15/2009 1:12 AM
You may also want to make sure exsiting batteries are wired in series in air/ga instrument. (most the time they are, but it is possible they are in parrelle to deliver more current or to last longer.) might want to make sure first. If device has plug in jack too, device voltage requirement most likely stamped on it.
Also search internet, ebay etc. for replacement 7.2 volt batteries from 3rd party supplier.
AB PLC Training onsite, On-Line, training software and more. BIN95.com
12/16/2009 12:04 PM
thanks.
I found my batteries. 2x 7.2v ni-cad. My charger output is 17dcv. Could this be why my batteries cracked? Do i need another charger with output of 14.4dcv?
Good Answers: 18
12/16/2009 3:59 PM
You need more than 14.4 volts to force current into your battery pack, and the charger should limit the current.
12/15/2009 9:29 AM
I have samplers that use 3.6v AA batteries, so I can sympathsize. A fully charged lead acid battery is 14.2v or so. The earlier comment about how your batteries are wired in is important. They could be 14.4v out or 7.2v. A 24v lead acid with a voltage/power (PVM) controller is worth looking into.
12/15/2009 10:56 AM
Hi Mr. Smyth,
It depends on the design of the equipment but generally no for the 9v battery the voltage will be too low. You can check with the manufacture to see the acceptable range. 2) 7.2v batteries is the best way to go. You can use batteries that add up to 14.4v but what you will find is that the discharge curves of the batteries will probably not be the same and you will not get optimum performance of the new batteries. The last thing to consider is the Amp Hour (AH) rating of the battery string; it need to be the same or higher than the original batteries or you will not get as long as a run time.
12/16/2009 12:10 PM
thanks
12/16/2009 4:12 PM
What type of gas are you sensing? If the equipment is classified for use in hazardous areas, you need to follow the manufacturer's manual and cautions. Different batteries will have different characteristics such as surface temperatures, max short circuit current, etc which could pose an explosion hazard.
As a rule of thumb, follow manufacturer's requirements, and if you're going to replace anything, make sure it's critical parameters are not exceeded.
Register to Reply 11 comments
Anonymous Poster (1); Apps Man (1); Bill (2); BIN95 (1); Graebeard (1); mrsmiyh (4); Paulusgnome (1)
