Previous in Forum: What Publications Do You Read for the Semicon Industry?   Next in Forum: Machinability of EN24
Jacketed and Cored Valve Bodies
12/15/2009 7:19 PM
The valve body shall be jacketed or cored to permit thaw-out using medium pressure steam. 4)Jacket/core temperature limits (maximum/minimum for each zone)(5)Barrel jackets or coring and operating modes shall be provided as listed below.
what does cored mean in this context?
I am not a home work cheater. I am a translator seeking professional help
Re: cored?
12/15/2009 7:27 PM
Drilled. material removed to allow steam passage?
That's my guess.
Re: Jacketed and Cored Valve Bodies
12/17/2009 8:25 AM
It probably refers to one made from a casting that is cored like an Engine Block is cored for liquid cooling.
Good Answers: 32
12/17/2009 11:01 AM
The valve would be designed as a double walled vessel where the valve compartment is in the interior made by a core or cores and the steam jacket passages would be accomplished by a second set of cores. The inner wall of the second set or cores creates the walls of the valve that the fluid is passing through while the outer most wall would contain the heating medium which could be either steam, hot water or other fluid.
These are used extensively in plants where molten sulfur is produced or utilized or where a minimum temperature must be kept to prevent the solidification of the product.
Jacketed would be more like a tracing where you wrap a coil around the valve and then insulate it to keep in the heat, much like you do with water pipes that can freeze up in the cold with an electric tracing wires which you then wrap with fiberglass insulation.
Spinco
Register to Reply 3 comments
lyn (1); Mechanicalmark (1); Spinco (1)
