Previous in Forum: Target Tee   Next in Forum: Blowers, Power and Volumetric Flow
HVAV Chilled Water System
12/16/2009 8:03 AM
An Engineer by Default has designed a chilled water HVAC system with DRV/Balancing walve in the inlet of chiller. Does anybody approve of this?
Re: HVAV-Chilled water system
12/16/2009 8:05 AM
What is, "An Engineer by Default"?
06/04/2010 1:40 AM
U r using computer and asking me what is "BY DEFAULT"
12/16/2009 8:19 AM
What is engineer by default define? for which applications were reported too? could you please describe in details on where these been address? e.g. ASHRAE, ANSI or etc. provide us with the detail description.
LifeCycle of Engineering
12/16/2009 8:54 AM
An Engineer by Default is a Butcher who is not professionally qualified but aways acts as one going arount butchering things he has no knowledge.
DRV/Blancing valves are installed in a HVAC system Chiller out let water line. If you install in the inlet, there will be turbulance in chiller and it will not be flooded with water which is must for super heating refrigerant to leave to compressor. U can see in CRANE valve cataluges the postion where this has to be installed.
12/16/2009 9:03 AM
<...install in the inlet, there will be turbulance in chiller and it will not be flooded with water which is must for super heating refrigerant to leave to compressor...>
Does the installation agree with the "for construction" P&ID?
  • If not, then change the installation so that it does.
  • If it does, then query the process and controls design with the relevant designer(s).
12/16/2009 9:11 AM
Thanks for the explanation. Butcher I understand. So, this Butcher put the goesoutta valve on the goesinna side?
Register to Reply 6 comments
khairul.asra (1); lyn (2); Padmanabhan Iyer (2); PWSlack (1)
