Previous in Forum: Blowers, Power and Volumetric Flow   Next in Forum: Gas Turbine Questions
First Article Inspection
12/16/2009 9:14 AM
What is a 'first article inspection' and why is it called so?
Re: first article inspection
12/16/2009 9:19 AM
It is a critical attribute inspection of the "first article" produced in a production run.
If the sample passes the "first article inspection" the run can begin without any modifications. That part is typically retained as a standard.
Good Answers: 32
Re: First Article Inspection
12/18/2009 11:49 AM
Under AS9100, AMS-A-21180 and some other specifications whenever a pattern is made, revised or even moved to a new foundry the first production run shall require a FAI or First Article Inspection where one casting of each impression on the pattern board shall be blued and laid out for each dimension (attribute) on the drawing as well as all Notes , specifications(x-ray, FP etc.) on that drawing shall be covered as having been met and reported on in a FAIR (First Article Inspection Report).
If the item is machined out of barstock then all dimensions and specifications will be accounted for on a FAI Report.
A bubble drawing (circled references to each item) is often also required.
Spinco
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
12/18/2009 12:02 PM
First Article Inspection is the first production (non-prototype) unit produced using the following:
  1. to a completed released design,
  2. the specified material(s),
  3. the intended production processes,
  4. production tooling and equipment.
  5. The inspection is to 100% of the design requirements (not just the critical features or requirements
Register to Reply 3 comments
Gannet (1); lyn (1); Spinco (1)
