Previous in Forum: Safe Release of Pendulum Bob   Next in Forum: Thermal Analysis of Composite Material with ANSYS Classic
8 comments
Volume of N2
01/17/2007 12:31 AM
What quantity of N2 (liquid) at 9 bar would be required for 100M3 volume.
your prompt response would be of great value as I need now please.
Good Answers: 19
Re: Volume of N2
01/17/2007 10:16 AM
Go to google type "volume n2" and down load N2 of Volume 11, N2 of Volume 14.
Maybe this may help you out. To me this seems french.
Re: Volume of N2
01/18/2007 12:25 AM
If a rough value is good enough, there is approximately a 2000:1 ratio of vapor at one bar to liquid volume (any reasonable pressure) for any liquid. Since the PV product is a constant, divide the 2000 by 9 to get 222. 100M3 vapor at 9 bar/222=0.45M3 of liquid.
Re: Volume of N2
01/18/2007 3:17 AM
  • Critical Pressure: 492.3 psia (33.5 atm)
  • Density, Liquid @ BP, 1 atm: 50.45 lb/scf " Wikipedia" Same irrespective of Pressure(ALMOST!)
Good Answers: 137
Re: Volume of N2
01/18/2007 5:12 AM
Can't tell what you're asking. It reads as if you mean what mass of liquid N2 is 100 m3 of liquid N2. Density of liquid N2 is about 800 kg/m3 so it's 80 tonne. But 100 m3 of liquid N2 is a lot so you more likely mean 100 m3 gas. At what temperature and pressure? At say 15°C and 1 bar (abs) density is ~ 1.17 kg/m3 so mass = 117 kg.
Presumably the 9 bar refers to the liquid N2 but pressure obviously doesn't affect the mass and as MUKULMAHANT said it doesn't affect density much either so volume of liquid is ~ 0.146 m3.
Re: Volume of N2
01/18/2007 5:48 AM
Haste is Waste!
Had you asked in plain English ,we would have reached our goal long back.
Are you asking this?:
How many Kg of liquid Nitrogen would completely fill a 100 cubic metre volume(which had been evacuated earlier) and then the N2 Gas will attain a pressureof 9 atg ?
Every word counts.
Good Answers: 137
Re: Volume of N2
01/18/2007 9:03 AM
Also need to know gas temperature
Re: Volume of N2
01/18/2007 10:47 AM
.... to be exact!
Re: Volume of N2
01/27/2007 8:49 PM
As I understand it, is quite simple.
Remember the formula: Pv=RT. Assuming the temperature will be the same (you will have the "space" at room temperature before and after pressurizing), you would need 900 cubic metres to achieve 9 bar in the 100 cubic metres space.
A better way is to call a Nitrogen provider to ask them. They usually give you the most accurate volume and cost alternatives..
Anonymous Poster (1); Codemaster (2); dkwarner (1); ducon (1); MUKULMAHANT (3)
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
