Previous in Forum: Testing strips   Next in Forum: ceramic wrap
Any Foam Sustaining 200Deg Temp
01/17/2007 2:07 AM
I have a requirement for a soft foam which is to be fitted on a part. The part is heated to a temperature of 200deg. so if any body knows any type of foam which can act as a foam even after heated upto 200deg then please reply.
My E-Mail ashish.moudghil@cgl.co.in
Pathfinder Tags: Foam For High Temperature
Re: Any Foam Sustaining 200Deg Temp
01/17/2007 3:45 PM
Most foam material will withstand a mere 200 degrees with out problem....
Now the question is what units are you using? Centigrade (Celcius), Farenheit, Kelvin, Rankine etc...
John.
01/18/2007 6:33 AM
I think I have what you are looking for it is a closed cell polyurethane but you can make it soft buy using volum control for more info you can call or e mail me
at.
EXspantion foam
kochi ken agawa
gun haruno cho
nino japan
ph. 81+0888-50-3710
cell 81+090-1171-9966
fax 81+0888-50-3740
for yahoo or skype messinger s
skype phone. anzaldua1
yahoo messinger . surftoohoosurfboards@yahoo.com
01/18/2007 11:17 AM
You can try high temperature silicone sponge if it will meet your requirements. It can handle temperatures up to 700°F.
01/18/2007 11:39 AM
Dilbert (nice id!) are you assuming the questioner is talking about degrees Farenheit?
02/14/2007 5:44 PM
zotefoams has nylon foams capable of sustaining 210C for 24 hours, 130C for continuous use. They are semi-rigid but thermoformable.
Anonymous Poster (1); dilbert451 (1); Electroman (2); suchi (1)
