Previous in Forum: medium voltage and low voltage ducts   Next in Forum: Grounding and bonding
Relay
12/18/2009 7:57 AM
Sir I want to know the advantage of using pilotwire protection relay & supervision equipment relay & SPAJ Relay in a substation in HT Switchgear panel.
Pathfinder Tags: Relay
Re: Relay
12/18/2009 8:56 AM
Dear Agni Mohanty,
There are many advantageous on pilot wire, especially a new type of Microprocessor relay. I have implemented for onshore plant and offshore platform with the distance around 20 to 24 km using fiber optic for relay comunication.
But I am still interested with your reply on "motor faults" subject. Do you have any information that already sent to you?
Regards,
RSM Elect Specialist
Re: Relay
12/19/2009 4:30 AM
yes boss moter may be fault appear due to falowing
moter over load _ cheque all electrical connections tight all
moter temperature high cheque all incoming signals and out going signals dc
moter tem low current - set moter tripped
Re: Relay
12/19/2009 4:50 AM
Dear Sir,
For motor protection we are using mostly The neumerical relays comprising of these functions i.e.- Short circuit/Earth fault/CB fail/Limit of load /loss of load/locked rotor /under & over voltage protections etc.
The relays are for motor protection are MICOM-P225,P141,P220
Re: Relay
12/19/2009 3:40 PM
I am specialize to sell realys
www.ramos.it
email mmoscati@iol.it
michele moscati
Register to Reply 4 comments
agni mohanty (1); Anonymous Poster (1); moscati (1); rasam.syamsudin (1)
