Previous in Forum: 2007 Hyundai - Transmission Problem   Next in Forum: What is the correct ATF for a 95 Dodge Cummins automatic tranny?
Dodge Ram 1500 truck acting goofy
12/19/2009 4:36 PM
My 1997 Dodge Ram 1500 4WD extended cab is acting goofy. First--and this is a continuing problem--it doesn't like to start. It has plenty of battery, but I have to jiggle the shift lever from Park to Neutral and back again, and finally it works. I get power to the starter, and it starts just fine. Once it starts, it will start again and again, no problem. Until the next day.
At the exact same instant this problem started, it suddenly refused to idle. Let off the gas, and it just flat died. Went from 1500 rpm to zip, and died. It was like turning the key off.
So I had my buddy come over with his computer to check the engine codes. Alas, I made the mistake of telling Mr 10 Mpg* (the truck) that my buddy was coming over, so--after I got it started--it decided to idle, like normal. The check engine light went out (it is usually on all the time because of a bad rear O2 sensor). When we scanned the codes, nothing came up. This is a classic case of Murphy's Law of Mechanics.
However, the ABS and Brake lights came on when my buddy was scanning, and now they stay on all the time. Truck stops fine, but the ABS/brake lights stay on.
Sounds to me that everything is related, but we can't figure out what it might be. Ideas, anyone?
*It gets 10mpg whilst towing the race car. Around town, 17 or so.
Life is like a sewer. What you get out of it depends on what you put into it.--Tom Lehrer
Re: Dodge Ram 1500 truck acting goofy
12/19/2009 8:25 PM
That is a lot of different symptoms. Sounds to me like you might have a loose wire(s) on the ignition switch.
*It gets 10mpg
Ahh. Reminds me of an old Hay Baler (International Harvester) truck I once owned. It got 10.3 MPG. Uphill, downhill, loaded, unloaded, it didn't matter.
12/19/2009 11:12 PM
Look for corrosion at the battery connection, if it's there, cut the wires back and replace the terminals and clean the posts.
12/20/2009 12:02 AM
both previous posts are valid suggestions. Park/Neutral issue sounds like a neutral safety switch, located either in the steering column, or transmission (google it)
The goofiness and misc issues with OBD makes me think of a bad ground somewhere. maybe a ground strap from instrument cluster/steering column/onboard computer?
Also the engine might have a bad ground. Makes for strange issues especially with starting and running (no idle)
I am sure a dodge fan will eventually see this thread, and give some solid suggestions.
start with the easy stuff, keep us posted on what you find. good luck
JohnnyB
12/20/2009 3:19 AM
Sounds like the wirng in the steering column to me and the nutral switch
Register to Reply 4 comments
dadw5boys (1); Franksgarage (1); johnnybravo (1); Kilowatt0 (1)
You might be interested in: SRAM Modules, Memory Modules, Hydraulic Cylinders
