Previous in Forum: Pump Motor Selection   Next in Forum: Weldolet vs. Reducing Tee
Belt Pulley Speed
12/22/2009 11:50 AM
Im setting up a new compressor and need to know what diameter drive pulley will be required to acheve the right compressor RPM
Gene Davies
Re: Belt Pulley speed
12/22/2009 12:54 PM
Right Compressor RPM / Available motor RPM = Motor Pully Diameter/ Compressor Pully Diameter.
Belt Speed = ∏.( Motor Pully Diameter). (Motor Pully RPM) / 60 m/s
Optimum belt speed must be (as I remember) around 20m/s
12/22/2009 12:55 PM
That's not enough information. I'd think the supplier of the compresser would help you. He's getting paid, isn't he?
12/22/2009 1:43 PM
Make sure and use pitch diameter to work out the ratio and not sheave OD. Although these two are close, the pitch diameter represents the diameter the v-belt actually drives the sheave at.
As has been implied, there is a little more to it than just getting the correct resulting RPM. Allowable belt load, how many grooves, belt velocity, etc.
Everything I know about opera I learned from Bugs Bunny
Good Answers: 49
Re: Belt Pulley Speed
12/23/2009 2:08 AM
Totally agree regarding get input from supplier. Also- definitely use at least 2 belts, and perhaps 3 (each sized for full HP load) for reliability and stretch resistance.
If the compressor will be starting-stopping frequently, I strongly also recommend a "soft start" controller to minimize wear on belts.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
12/23/2009 9:20 AM
You find the RPM of compressor it should operate from the supplier. If you select bigger Dia. of motor pulley compressor may rotate more RPM than specified RPM. So the life of compressor will come down. Bearing and oil seal may worn out quickly.
If you select smaller dia motor pulley compressor may rotate low RPM. You may get proper performance/output from the compressor. So compressor should rotate in the correct RPM. which will be given by the supplier.
To find the motor pulley Dia come back to me after getting compressor RPM from supplier.
Good Answers: 68
12/24/2009 10:59 PM
Hi RAMBLER3-TOO,
This may help.
I searched for the ratio of the drive pulley to the motor speed.
  1. Pulley And Belt Information CalculatorThe ratio is the driver pulley size diameter divided by the driven pulley size diameter. ... (usually known from the motor speed) while the output RPM is the speed of the driven pulley. ... Drive Pulley Ratio, Variable. Belt Information ...
    www.csgnetwork.com/pulleybeltcalc.html - Cached - Similar -
  2. JSS GEAR RATIO CALCULATION: Student Handout 6Motor Speed, wm, 8300 rpm, (revolutions per minute) under load .... For a Pulley System we might select a drive pulley of 6 cm in diameter. ...
    eagle.csd49.org/middle/jss/Course_GearCalc.htm - Cached - Similar -
Hope it helps. If not get in touch.
01/03/2010 10:49 PM
Rambler,
Nice question but i think you should get a professional engineer on the job
Anthony@ALNO
http://www.alnoproductservices.com.au
Register to Reply 7 comments
Anonymous Poster (1); Anthony@ALNO (1); babybear (1); DaveB (1); dhanramesh2002 (1); energygod (1); lyn (1)
