Previous in Forum: Wish you all the best   Next in Forum: HomeLand Security
9 comments
PIPE CHUCKS
12/24/2009 2:44 PM
Is there anything out there I could use to grip a round tube and mechanically rotate it with high torque.
I install screwpiles using a torque motor which attaches to the end of the pile with a collar and pin system. This method nessitates the pile to be in short pieces (ie. around 2mtrs long). If I am installing a 6mtr pile, it has to be in 3 pieces which reduces its lateral stability.
I was hoping that there might be an apparatus that could open and grab the pile and then rotate it. I could then drive full lengths of pile by sliding the apparatus up the pile and re-gripping it in different places along its length.
I was visualising some kind of off-set toothed cams for gripping the pipe maybe.
Good Answers: 58
Re: PIPE CHUCKS
12/24/2009 3:49 PM
I see plenty of large mechanical drivers for this job, they look like drill rigs for power poles. Maybe the power company sells them used.
To make your own, and you would need a good fabrication shop, I would do something like what I see the oil drillers doing with a chain.
There is a special pulley called a cat head, I think, it's for chain. Somehow a lot of wraps are put around your screwpile and then one around the cat head. An opposing set of small wheels keep the chain tight on the pile. Hopefully the pile doesn't go into the ground faster than the chain walks up the pile.
You could also use motorcycle type chain, if it were loose enough to spiral around the pile. The trick is the master link to make either chain endless.
Keep your fingers out of the way!
mike k
Good Answers: 93
Re: PIPE CHUCKS
12/24/2009 5:46 PM
Cooper Tools might make something you could either use, or adapt, or would illustrate a direction to go in for fabricating the specialized mechanism you may need.
Pole axes and chain Vicegrips come from the need to grab round same as even the monkey wrench have long been around.
Then there is the strap wrench.
Some strictures may apply to your application as far as damage to what you are grabbing.
We often used Chain Vice grips with 750 pins for mounting lights on pipes, but these are film things come from Matthews.
Some of these tools if not directly applicable to your work, will at least point you towards the concepts. Gotta go. Wife says wrap it up!
You don't get wise because you got old, you get old because you were wise.
Re: PIPE CHUCKS
12/24/2009 8:19 PM
Depends on the diameter of the piling.
What about reasonably priced tail pipe expander?
Re: PIPE CHUCKS
12/25/2009 12:02 AM
Google 'casing tongs' Eckel makes some fine ones, they'll turn anything...
Finish your beer! There are sober kids in Africa!
Re: PIPE CHUCKS
12/25/2009 4:38 PM
I have googled casing tongs and they seem to be close to what I am looking for. Is there anyone in the UK selling these things or where might I find a secondhand one for testing.
Re: PIPE CHUCKS
12/25/2009 7:44 PM
The oilfield service providers in Aberdeen would be a start. Try Weatherford, they make and rent them, I don't know if they sell them though.
Re: PIPE CHUCKS
12/26/2009 6:17 AM
Thanks Rockbit.
By the way are you connected with piling or similar stuff, based on your user name.
miik999
Re: PIPE CHUCKS
12/29/2009 2:38 PM
Thanks Rockbit.
Are you connected with piling or similar stuff, based on your user name.
miik999
Re: PIPE CHUCKS
12/29/2009 7:08 AM
The first thought that came to mind is the strap wrench. A development of something like that, maybe?
Register to Reply 9 comments
Anonymous Poster (2); miik999 (1); mike k (1); PWSlack (1); qaqcpipeman (1); rockbit (2); Transcendian (1)
