Previous in Forum: factory acceptance test   Next in Forum: Non Material Requirements (NMR)
How to prohibit forcing outputs in PLC
12/26/2009 11:07 AM
Dear All,
Happy new year.In our plant, we are having S7400 PLC. In case of any force of output coil in the logic, it will result in accident. Is there any provision to prohibit the forcing of Outputs? Please help me.
Thank you
Re: How to prohibit forcing outputs in PLC
12/27/2009 12:46 AM
Best way is to apply "Password" protection for the plc program to avoid any interference from any unauthorised person.
12/27/2009 1:58 AM
in the logic you can not prohibit....but in configuration you can deactivate it.
or better put password.......best option.
I would tell you very clearly if i would know which brand you are using.
12/27/2009 3:34 AM
I have seen in S7300 PLC, the inputs can be forced, but outputs (M coils, Q coils)can not be forced. So it would be possible in S7400 also. But i don't know how to do it.
12/29/2009 6:04 AM
Safety-critical systems are best hard-wired through keyswitches or lockable isolators and their use controlled under a Permit-to-Work system that encompasses positive isolation.
12/30/2009 6:52 PM
If any output fails "on" will it also result in accident?
If this is the case, all the outputs (or power to the outputs) must be run thru a safety circuit to prevent "on state failures" from accidents.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
Anonymous Poster (2); Lspraba (1); MIKE L. (1); PWSlack (1)
