Previous in Forum: NGR Sizing for Three Parallel Generators   Next in Forum: Bi-Directional Power Flow in OLTC
Power Cable Sizing
12/28/2009 1:07 AM
Dear friends
kindly tell me that how we will calculate the size of power cable with respect to load current ???
Re: power cable
12/28/2009 3:27 AM
which cable you want to size is it LV OR HV cable? LV cable sizing is done current carring capacity where as HV cable sizing is done on mainly fault current.
Re: power cable
12/28/2009 4:11 AM
first thanx for reply
tell me if there is 33 KV, 87.0 Amp. load then what is criteria to select the cable size. ,is there any formula for selection process .
Re: power cable
12/28/2009 5:05 AM
As i mentioned we also should know the fault level of the system that is in KA .that is the main criteria for HV cable sizing.Because even 33KV 3CX25 sq.mm cable will also carry your 87A current .but this is not correct method to size cable.Pls tel mi the fault level of system.
Re: power cable
12/28/2009 6:11 AM
the fault level is 31.5 KA
Engineering Fields - Electrical Engineering - New Member India - Member - New Member
Re: power cable
12/28/2009 5:42 AM
please refer website http://myelectrical.com/pages/tools/tools.aspx... hope this helps
Regards
Re: Power Cable Sizing
12/29/2009 5:45 AM
This question has been asked hundreds of times. Please use the search facility provided before posting on this forum. You will find that a large number of queries have already been discussed in detail in numerous threads.
Atlas Shrugged - JGD
12/29/2009 7:57 AM
→ British Standard 7671.
Anonymous Poster (1); Current Maarey (1); Gyan (1); luv123 (2); PWSlack (1); shanbhag (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
