Previous in Forum: Indian Standards for 33kv Bus Height   Next in Forum: How to Build LV Panels
How to Select Armored Power Cable
12/28/2009 6:32 AM
Various types of armours are available for power cables.
eg. Flat wire / round wire / double tape.
What are the factors which decides selection of type of armour ?
I have to choose for 3Cx400 Al. 33kV UE XLPE cable. What should be my choice?
Re: How to Select Armored Power Cable
12/29/2009 1:02 AM
One factor to ALWAYS consider is the environment in which the cable will be laid. The metal that makes up the armor must be compatible with the atmosphere, water drippings, mists, etc. to which it'll be exposed else it'll corrode, grow brittle, and break.
This was a major issue at an underground copper-nickel mine where I consulted for a short while. The original cables were aluminum-armored ones and they caused headaches without end to the mine's operations and maintenance staff. Many had to be out and out replaced ... which is VERY expensive and time-consuming in an underground mine.
Cheers! DZ
And don't let anyone tell you that plastic (or whatever) sheathing will protect the armor. ALWAYS ensure that the armor's metal is compatible with the environment where it'll be applied.
01/04/2010 6:01 AM
I am asking about construction of armour. ie. selection of round wire or flat strip?
Material is OK.
12/29/2009 7:55 AM
→ British Standard 7671.
Good Answers: 12
12/29/2009 1:10 PM
Don't forget to consider the current surge. I've seen cabling systems tear themselves apart in an application that had high surges several times a minute. Originally the cabling was sized for average current. The solution was to install multiple smaller cables which both provided some extra capacity and more mechanical strength.
Anonymous Poster (2); PWSlack (1); Snave (1)
