Previous in Forum: Building Management System (BMS) Logic   Next in Forum: Valve Cv rating?
Noise Abatement Trim
12/29/2009 5:47 AM
Please provide details on the cause of Noise in Valves. Any suggestion on how to eliminate it. thanks
Re: Noise Abatement Trim
12/29/2009 5:54 AM
Reducing the pressure drop across them is one way. Then, what is a valve other than a means of isolation and of dropping pressure/flowrate (rhetorical question)?
Butterfly valves in particular can exhibit this characteristic, and in their particular case, vortex-disturbing "fingers" can be added to the trailing edge of the disc so as to reduce the problem.
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
