Previous in Forum: Flow Orifices in Pipes   Next in Forum: Muffler Pressure Question
Air Blower/Compressor Needed
01/19/2007 4:46 AM
Hello everybody!
This is my first contribution (actually question) to this forum. I have followed it a bit though and I find it quite interesting and it has been also already quite useful in my work. At my company we are developing PE fuel cells (www.ceka.ch).
Now, I am looking for air blowers and/or compressors in the range of 10 normliter/min (0.01m3/min) to 70 nL/min (0.07m3/min). The desired overpressure is in the range of 100 to 500 mbar.
Important criteria are volume, weight and power consumption of the blowers/compressors.
Has anyone a good tip or even info on this? I thank all in advance.
Regards,
Marco
Pathfinder Tags: blower
Re: Air Blower/Compressor Needed
01/20/2007 1:33 AM
The volumetric flow rate is too small for any commercial positive displacement blower that I know of. Your best bet is to look at small diaphragm compressors used for air brush applications.
Check out vacuum@tuthill.com for more information regarding blowers.
01/20/2007 6:23 AM
http://www.eccentricpumps.com/?OVRAW=Peristaltic%20Pump&OVKEY=peristaltic%20pump&OVMTC=standard
They will have all - including a variable Speed motor to cover range of flows you need.
01/22/2007 10:26 AM
The duty looks similar to a compressor used for spraying paint onto miniature models by hobbyists. In the UK, £60 upwards would secure one that plugs into a domestic appliance socket.
An alternative to an air compressor for limited applications is the canister containing an inert propellant. In the UK they can be had over-the-counter in model shops for £3.5 onwards, though of course they don't contain breathable air.
Register to Reply 3 comments
MUKULMAHANT (1); Nymoc46 (1); PWSlack (1)
