Previous in Forum: lv panel   Next in Forum: rectifier
Digit Display
12/30/2009 5:27 AM
hi freinds,
Can any body tell me the difference between 4.5 digit display and 4 or 3.5 or 3 digit display. what is the maximum count we can measure by these digit display.
Re: digit display
12/30/2009 5:43 AM
It's very simple, Captain.
  • A 4.5 digit display goes from 0 to 19999.
  • A 4 digit display goes from 0 to 9999.
  • A 3.5 digit display goes from 0 to 1999.
  • A 3 digit display goes from 0 to 999.
Just select the one you want.
Good moaning!
Good Answers: 53
Re: digit display
12/30/2009 5:48 AM
Below are max counts for each type you had asked for.
4.5 digits 19999
4 digits 9999
3.5 digits 1999
3 digits 999
Additional info
4.75 digits 39999
3.75 digits 3999
Re: digit display
12/30/2009 10:19 PM
Dear friend
Thanks for your reply.
Please give me the detail calculation method for obtaining these maximum count.
Reply Off Topic (Score 4)
Re: digit display
12/31/2009 3:28 AM
Start by stating the number of significant digits that are required in the display.
Need Some help in designing plate Bending Machine.
01/03/2011 12:53 AM
Hi... Everyone...
I am designing 3 roller type pyramidal plate bending machine with pre bending facility.
Machine's capacity will be to bend M.S. Plate of Thickness 40 MM & 3000 MM Width.
Both the Bottom Rollers Will be Driven By Planetory Gear Box .
Top Roller Dia is 450 MM (Material EN8 Forged)
Bottom Rollers Dia is 390 MM (Material En8 Forged)
Minimum Dia of 40MM Thickess which shall be bend is 1800 MM
Top Roller of the machine will be fixed & bottom rollers will move up & down with the help of hydraulic Jacks.
I want the RPM of Bottom Rollers 1 to 1.5 RPM
kindly help me in this points :
1. What Size of Jack & Cylinder I should use for bottom Rollers ?
2. How Much Hydraulic pressure will be required to successfully bend 40 MM thickness Cylinder ?
3.Size of planetory gear box i should use ? ( I am thinking to buy of boschrexroth make) If want me to use any other company kindly suggest ?
4. Torque of the required gear box ?
5. Electric Motor in H.P. to be used in each bottom roller ? & RPM of motor ?
i will be very thankful to you .
Kindly contact me at
Anonymous Poster (1); Crabtree (1); mukeshpt (1); PWSlack (1); rakesh_semwal (1)
