Previous in Forum: Digit Display   Next in Forum: Wi-Fi want to control plant lights remotely
rectifier
12/30/2009 12:35 PM
mode of operation and DIRECT CURRENT affiliation
Re: rectifier
12/30/2009 1:05 PM
What are you talking about? Is there a question in there somewhere?
Good Answers: 29
Re: rectifier
12/30/2009 2:54 PM
A rectifier is an electrical device that converts alternating current to direct current. These days most rectifiers are constructed of solid state devices called diodes. In the past vaccuum tubes were used. Half wave rectification is accomplished with two diodes and creates pulsed DC, whereas full wave rectification requires four devices and creates complete direct current by converting both polarities of the input waveform. Devices that convert DC to AC are called Inverters. Now, what's the question?
Re: rectifier
01/15/2010 2:25 PM
thank you and my question was the actual mechanism of it ,or an animated version of it ,,if you have it
thank you in advance for your effort to help help me out
Register to Reply 3 comments
BiomedWV (1); gichohime1991 (1); RDGRNR (1)
