Previous in Forum: Wi-Fi want to control plant lights remotely   Next in Forum: DC Load banK
IP 55 Rating vs NEC article 502 - Class II Locations
12/30/2009 7:04 PM
HI~!
Happy new year everyone.
I'd like to ask what IP 55 rating corrspond with NEC article 502.8 'Motors and Generators' class II, Division 2.
If anyone know or can explain that my question, please send me e-mail 'jeongse.kim@doosan.com'.
thanks,
jeongse
Re: IP 55 Rating vs NEC article 502 - Class II Locations
12/31/2009 1:53 AM
IP ratings are for the suitability of the equipment for mechanical and water ingress protection. Whereas the class II Div 2 ratings are for suitability of equipment for working without causing a hazard when such equipment are installed in hazardous classified areas.
Atlas Shrugged - JGD
12/31/2009 3:25 AM
Good Answers: 244
12/31/2009 3:29 PM
Guest,
First of all, you are comparing two different things – IP (Ingress Protection) is completely different from what is mentioned in NEC article 502. I don't think there is anything in NEC that is comparable to IP (CENELEC). However, the NEMA enclosure type is comparable to CENELEC IP (http://www.nema.org/prod/be/enclosures/upload/NEMA_Enclosure_Types_11-05-2.doc)
NEC article 500 (Hazardous Locations) can be compared to IEC 60079.
See the following links for further help:
http://www.stonel.com/pdfs/process_environment.pdf
http://cr4.globalspec.com/thread/44009
Happy New Year everybody
- MS
Current Maarey (1); msamad (1); PWSlack (1)
You might be interested in: IP Cores, NEMA and IP Enclosures, VoIP and IP Telephony
