Previous in Forum: Expandable Polymer   Next in Forum: Tire Shin water based organic polymer
abrasive membrane for deburing harden stainless steal
12/30/2009 11:06 PM
finding abrasive membrane thats semi flexable,with a light abrasive coating that can be used to debur an or fine edge hardened stainless steal useng a motor between 1800-2800 rpm
Re: abrasive membrane for deburing harden stainless steal
12/30/2009 11:12 PM
How about sandpaper (or cloth), which comes in various configurations (sheets, disks, belts, cylinders) that might work?
12/30/2009 11:37 PM
i really need a product that can sustain a lot of usage that i can incorporate into a prototype
12/31/2009 12:10 AM
Then maybe as a step upward, consider grinding wheel type products--disks, cups, cones, etc. There might even be diamond-grit products in a good configuration. You might want to approach Norton or other abrasives makers with some queries.
12/31/2009 12:59 PM
May be an application for a buffing wheel, and Jewellers Rouge:
[Compliments of Wiki] A very fine powder of ferric oxide is known as jeweller's rouge, red rouge, or simply rouge. It is used to put the final polish on metallic jewellery and lenses, and historically as a cosmetic.
Rouge cuts more slowly than some modern polishes, such as cerium(IV) oxide, but is still used in optics fabrication and by jewelers for the superior finish it can produce. When polishing gold, the rouge slightly stains the gold, which contributes to the appearance of the finished piece. Rouge is sold as a powder, paste, laced on polishing cloths, or solid bar (with a wax or grease binder). Other polishing compounds are also often called "rouge", even when they do not contain iron oxide. Jewelers remove the residual rouge on jewelry by use of ultrasonic cleaning.
Jewellers Rouge is about the finest abrasive for a buffing wheel... coarser grits of rouge are available, for more agressive material removal.
Register to Reply 4 comments
davidg57 (1); Doorman (1); Tornado (2)
You might be interested in: Abrasive Belts
