Previous in Forum: section beam   Next in Forum: abrasive membrane for deburing harden stainless steal
Expandable Polymer
12/30/2009 3:39 PM
I am looking for a polymer that expands after applying some pressure between the fingers, as a result of piezoelectric or other mechanism.
Pathfinder Tags: polymer
Good Answers: 50
Re: Expandable Polymer
12/30/2009 11:57 PM
Does it have to be a polymer? Does it need to remain liquid?
12/31/2009 1:34 AM
Do you just want to amuse yourself, or do you have some real purpose in mind for this polymer that you squeeze between your fingers?
12/31/2009 10:46 AM
I am serious. I am looking for self expanding polymers to use in medical applications, like stents, but with the property of being expanded by touch.
Popular Science - Weaponology - Cardio-7
12/31/2009 11:52 AM
One possible way would be to mimic the human penis, by including small flexible tubing in the polymer, with the tubes attached to a very small pump. Touch the switch, how big do you want it to grow? The liquid medium could be water, glycerine, etc or air, nitrogen, argon, etc. Sort of like a blood cuff. Another way would be to use a polymer that absorbs water, briefly immerse the polymer and watch it swell. It might be possible to make the polymer as you suggested by using a liquid crystal polymer which responds to changes in touch, temperature, etc. What ratio of growth to original volume are you looking for?
12/31/2009 12:03 PM
Are you familiar with heat shrinkable sleeving used in electronics? It's heated, expanded over a mandrel and cooled. Then it's slipped over the wire, heated and it shrinks back to as near it's original size as allowed.
Perhaps there's a way to reverse this process. Shrink the stent, insert it and some combination of body heat/chemistry/electrical impulse will cause it to expand.
Good Answers: 109
12/31/2009 12:33 PM
Forget about Piezos,
this reqires other means.
Discussion is possible only confidentially.
RHABE
Good Answers: 25
01/04/2010 9:12 AM
Goodness has nothing to do with it.
Register to Reply 7 comments
beriberi (1); bio2000 (1); Cardio07 (1); lyn (2); RHABE (1); vermin (1)
