Previous in Forum: Ternary Solvent System   Next in Forum: Expandable Polymer
section beam
12/30/2009 4:34 AM
why do we mostly use of I section beam instead of other section beam?
Re: section beam
12/30/2009 4:37 AM
shows a bridge with oval-section beams over the River Tamar, in Cornwall, designed by Isambard Kingdom Brunel.
Re: section beam
12/30/2009 6:24 AM
I'm not sure that this is true; I have seen more W sections than the other types.
Generally, the best way to achieve high strength in a beam is to use high depth of the beam. "I" shapes do this, but sometimes the vertical space is limited, so you need a shallower but heavier beam (W, box, rectangular tube, etc.) Study up especially on section modulus and moment of inertia properties of the various shapes and sizes.
Good Answers: 183
Re: section beam
12/30/2009 3:16 PM
It is an economical aspect:
an I beam profile offers for bending the lowest specific weight for a given W (bending module) and can be also used for traction.
the profile is symmetric and is light to mill so that economy of weight + reduced cost/kg.
If loads are compressive then a circular or oval section are more economical. However in many cases due to prices /kg profiles build from 2 I beams welded together are preferred.
For instance a I-100 DIN profile has a ration Wx/G= 410.07 cm^3/kg G[kg/cm]
A rectangular section with same weight/cm and same hight has a ratio of only 21.23 cm^3/kg which shows the I as being 19.3 x more interesting.
nick name (1); PWSlack (1); Tornado (1)
