Previous in Forum: ss welding   Next in Forum: material grating
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Floor Coil Heaters
12/31/2009 1:02 AM
i have a fuel oil tank which has mat type floor coil heaters at the bottom. these heaters are resting on support nade of steel. i wanna know if these steel supports are to be coated with anti corrosion paints or not since they are to be immersed in the fuel oil inside the tank. any help will be appreciated...
Varun Passi
Pathfinder Tags: floor coil heaters fuel oil
Re: floor coil heaters
12/31/2009 3:43 AM
Are these supports made of the same material as the rest of the tank?
12/31/2009 10:44 AM
yes they are of IS 2062 gr. B. i was told that if the tank inners are coatd for protection then since the supports are immersed in oil even they are to be coated. i would like to know if there is any code or reference to support the explanation.
Register to Reply 2 comments
