Previous in Forum: Different Conditions in Which a Surge Divertor is Used ?   Next in Forum: Pulse Oximeter - Period Calculation Algorithm
Malaysia - Member - Kimie
Condenser Motor
12/31/2009 2:07 AM
Hi.......Could I use condenser motor 750w, 960rpm (400V/60Hz) instead of 580w, 900rpm (415V/60Hz) motor? Does other effect could arise if I decide to use this motor? Please advise.tq
Kimie
Re: Condenser motor
12/31/2009 3:21 AM
In principle, yes electrically, though the arrangement will be less energy-efficient. The larger motor will be doing a smaller percentage of its available output. Starting currents will be higher, and this needs to be taken into account in the design and selection of the motor overload protection device, the power circuit protection device and the power circuit conductor sizes.
Mechanically, why is there a difference in speeds, and does this matter to what is being driven?
Re: Condenser Motor
12/31/2009 9:41 AM
You could not if it were vice versa. But as it is, you can simply put a restriction to the air flow to avoid overcondensing, if necessary.
Re: Condenser Motor
12/31/2009 6:48 PM
Are you using the same fan blade, moving it from the old motor to the new? (If it is the same blade, 580 (960/900)3 ≈ 704 W < 750 , so this aspect looks okay.)
If the new motor will use a different blade, you should compare the air flow of the old and new combinations; the new one should have equal or a bit greater flow.
The difference between 400 and 415 volts may be within the permissible range of either motor, but you might want to check that, too.
Register to Reply 3 comments
PWSlack (1); Tornado (1); Yuri B. (1)
