When no heat was found circulating through the baseboard heating system, I went to the furnace room in my bare feet and felt the pipes. I immediately felt a slight tingle in my hand that from experience I have come to identify as a voltage potential trying to get to the cement floor. The floor was dry. In retrospect I realize that had the floor been wet, I might well not have survived to write this post.
The problem now is to identify the cause. My first inspection will be to see that the heavy copper system ground is in fact grounded at both ends. I dare not disconnect it as I no the dangers associated with doing so.
The copper pipes in both heating and domestic water have heavy gauge copper ground wires. Some of pipes are used to provide a convenient ground for nearby 3 prong duplex receptacles. This is an interim cure for a problem caused by the simple fact that some wires were installed 70 years ago. (two wire, no ground, no BX casing). More recent wiring is 3 or 4 wire Romex.
I know this system needs a serious overhaul and a new service entrance with at least 200 amp capacity. For the time being at least, I need to address this shock potential. I have test equipment and know how to use it. What I need is a methodology by which the possible causes can be investigated
Thanks
