Previous in Forum: I Want to Fix this Oscilloscope but....   Next in Forum: AC bridge variable resistor drive
Transmitter
01/06/2010 3:47 AM
how can we identify, a transmitter is self powered or loop powered?
Re: Transmitter
01/06/2010 3:52 AM
If it is loop-powered, it only has 2 wires.
Re: Transmitter
01/06/2010 4:06 AM
But some fuel oil flow transmitter and oxygen analyser are mentioned as 2 wire self powered. How can we identify those transmitters?
Re: Transmitter
01/06/2010 4:23 AM
Read the manuals that come with them.
Re: Transmitter
01/06/2010 4:32 AM
I don't have manual regarding this one. I'm new to the power industry, im a fresher. if u help me, it will be useful to me.
Re: Transmitter
01/06/2010 5:02 AM
Get on to the suppliers and ask for them, or visit their websites.
Re: Transmitter
01/06/2010 7:22 AM
Thanks for your suggestions.
South Africa - Member -
Good Answers: 12
Re: Transmitter
01/06/2010 4:02 AM
Hi there,
This has been answered before.
To make absolutely sure: read the manual. You can also refer to the specification plate on the transmitter.
Some transmitters require external power 100-230VAC, but the signal lines may still be loop powered. (Found in some Khrone Ultrasonic flow meters)
As a general rule of thumb (use at your own peril if you are not going to read the manual): If the transmitter only has two wires, i.e. the signal wires - it is loop powered.
If the transmitter has four wires, i.e. two for signal and two for external power - it is self powered.
Regards,
Craig
Register to Reply 7 comments
craigza (1); Jeba Keziah (3); PWSlack (3)
