Previous in Forum: What is DFMAA..???   Next in Forum: H.I.C. Resistance Material
Centrifugal pump start
01/06/2010 5:34 AM
Why we need to fill the centrifugal pump with prime before we start pump?
Re: Centrifugal pump start
01/06/2010 6:15 AM
Several reasons. Here are some:
  • They do not pump air
  • They do not self-prime
  • They need a seal wetting fluid for the seal to survive
01/06/2010 7:47 AM
A centrifugal pump will deliver a certain head against system back pressure, say 100m.
If full of air, the pressure developed will be, say, 100m of air - not very much pressure and insufficient to push it's way out of the pump and so draw liquid in. We say the pump is not self priming for that reason.
A self priming pump has a space where liquid partly covers the impeller so it can be thrown out and entrain the air in the pump at the same time. If it doesn't pull out enough air to prime the pump, the liquid falls back into the impeller, entrains more air, etc.
The above is a very much simplified version of what happens but I hope it will provide some clarification.
You might be interested in: Centrifugal Pumps, Form, Fill and Seal Machines
