Previous in Forum: Corten steel   Next in Forum: Decentralization of Electrical Power Production
13 comments
Buzzing Garage door opener
01/06/2010 11:23 PM
I have a chamberlain 1/2hp garage door opener. Door is 7 hght x 16 wide, steel pannel insulated, menards brand. I push the button, hardwired, and it just clickes then buzzes, stops , & does it again. I am using the door manually now. I waited over night encase it over heated, but find that hard acct its 11 degrees here in Omaha, NE... Same thing the next morning. It was working fine, the door opened to scoop snow and 30 minutes later it just clickes & buzz. If I do have to replace the opener is there any one brand/type that can be shortened account of I-beam. I have tight against the ceiling & bottom flange of the I-beam. I have checked the sensors, cleaned the eyes, and have the green light on both. Thx John
Re: Buzzing Garage door opener
01/07/2010 12:35 AM
I have had this problem and it was a stripped gear. The gear was plastic. Unplug the opener and remove the casing. In the event that this is the case, you will find plastic shavings and the damage to the gear will be apparent.
01/07/2010 11:35 PM
No broken gears... if they were broke, wouldnt the opener just run & never shut off? cuz it would not hit the stop on the other end... I am guessing it is a capacitor or transformer??? but how do you test them?
any other ideas? besides a BFH?!?!?
Good Answers: 97
01/07/2010 4:08 AM
This happened last year and after several minutes of frustration I found the installation and user manuals and reset the parameters. Then presto it worked again fine.
How it got out of adjustment
01/07/2010 11:32 PM
The opener was in the house when I bought it. So no instructions. What are the parameters that you are speaking of?
Good Answers: 97
01/08/2010 4:47 AM
The "range" and Force" adjustments. On the rear and/or side of the unit are small indented adjustment screws with indicating arrows.
The instructions are in my pole barn, outside temperature is only about -10°F but the wind chill is about -42°F so tomorrow I'll post the sequences.
Chamberlain is a fine quality opener
01/08/2010 7:22 AM
I agree with the post about changing parameters. The garage probably settled or moved slightly due to the seasonal changes in weather. The "click buzz, stops, and does it again" is your opener trying to come down - stalling - and then hitting the return cycle - stalling and stoping. If the door comes down and you stop it safety dictates it reverses (so no one gets pinned) if it goes up and stalls safety dictates it just stops (so nothing gets crushed upwards, the door breaks, or something gets picked up only to drop from a few feet up). You can probably fix the problem with adjustment of the force parameter (On a Chamberlain it should just be a screw to turn - it is probably labeled with a D for down or a F with a down arrow next to it).
You want to increase the force just enough to make it work. If you adjust so high that you can't force a reversal of the door by pulling up by hand as the door is closing, you have a serious safety issue on your hands. If it comes down on someone it could injure (seriously) or even kill them (a small kid that gets knocked over then crushed by the door pushing down on chest/stomach). It will also crease your car for you if you foolishly/accidentally push the button while the car is under the door.
IF the door won't work unless you turn the force up "too high", then only do it for the short run and fix it as soon as possible.
I once bought a house with a garage that was litterally torqued several degrees from floor to top of wall and the roof was sway-backed as an old horse. The garage door worked fine. I straightened it (slowly over a couple of weeks with well-placed come-alongs), rebraced it straight and made it look like new. Lo-and-behold the garage door quit working! I had to actually disassemble the side tracks and put it back together with everything straight/parallel/plumb to the (new) world. That winter when the weather got cold the door quit working, and I had to change the parameters for the door due to movement. Same thing in the spring. Finally I just loosened the track screws enough to allow them to spring to where they wanted to be with the door closed and it never had trouble after that. There must have been enough non-straight-ness in the framework to bind the door until it was allowed to find it's own reality, and then life was good. Hopefully, your door/garage is not that far out of whack!
Good Answers: 25
01/08/2010 8:18 AM
There are repair blogs on the web that address all manner of glitches and sell repair parts. I have saved a lot of time and money with nagging little appliance problems like this. A few minutes next to your warm computer can save you hours of frustration in a cold garage.
Goodness has nothing to do with it.
01/08/2010 10:12 AM
Since it is a chamberlain you should be able to find the model number on the tag located on the unit. Chamberlain units are fairly dependable and most of the time easy to repair. Once you have the model number you can do a search and most likely you will find the manual. Chamberlain also has a website with information on their units. It could be the control board which depending on the model is replaceable and not as expensive as replacing the unit itself.
God Bless everyone!
01/08/2010 6:56 PM
Its very cold out it will probably work when it warms up. On the back by the bulb are two tension adjustments. Increase the setting on both the up and down position. Probably around 9 for your temperatures. It takes a small screwdriver to turn the setting.
Good Answers: 97
01/09/2010 1:46 AM
The manual will call for white grease to lube the rail but silicone is your friend
Other posters have given good advise of control features and adjustment procedures however unplug and replug the unit then press reset before adjustment.
I remember a similar instance and the cure was re - synchronizing the remote and unit, big words for resetting frequencies.
01/10/2010 12:12 AM
You may have a bad capacitor in the circuit. I am not familiar with the Chamberlain opener, but the symptoms you describe are the same for a bad capacitor. Take off the cover remove the capacitor and have it tested. It should be close to the rated value printed on the capacitor's case. If it is more that 10% low, replace it.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
01/10/2010 1:42 AM
for those who want to DIY, here.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
01/11/2010 11:50 AM
Did you try to operate it after you decoupled the door from the drive? This eliminates binding as an issue and reduces starting torque.
If so, ignore force adjustment issues for now and focus on cap or relay (check for arcing if relay has transparent case)
The purpose of a system, is what it does.
Anonymous Poster (2); beriberi (1); bwire (3); Frank Designs (1); hioptemp (1); jamesw (1); langyaw (1); Mikerho (1); rhandwor (1); rickwil (1)
You might be interested in: Garage Doors, Door Operators, Door Stays and Lid Stays
