Previous in Forum: P-91 material application   Next in Forum: stratopower hydraulic pump
Boiler Operations
01/08/2010 2:34 PM
I WANT TO KNOW ABOUT FOLLOWING :
1.By monitoring the exhaust steam tempreture , the blade deposition in steam turbine can be predicted. how?
2. what is the process of stress releaving after welding process of a large equipment ?
3. why PH value of the steam is reduced after evapouration of boiler water while the PH value of drum water remains high ?
4. how and where MPI(magnetic particle inspection) test is performed?
This discussion was "closed" on 01/08/2010 2:51 PM. No new comments are allowed.
Message from admins:
CR4 is not a homework cheat site.
Re: BOILER OPERATIONS
01/08/2010 2:40 PM
Homework?
01/08/2010 2:47 PM
This forum is certainly less expensive than textbooks!
It appears none of his classmates will share their notes.
OP has 7 posts; 6 of them are questions regarding boiler operation, and the other is a snotty response to a member.
Register to Reply 2 comments
You might be interested in: Boiler Services, pH Electrodes, pH Transmitters
