Previous in Forum: Boiler Operations   Next in Forum: Teaching Microsoft LAN
10 comments
stratopower hydraulic pump
01/10/2010 2:19 AM
hello all. I am in dire need of an understanding on how a axial piston type variable displacement hydraulic pump works. i am an aircraft student and am looking for a video to show me exactly how one of those machines operate. I have literature on how they work but wont disregard any kind of wisdom any of you fine people might want to share with me. thank you and may God bless you. - Steve
Re: stratopower hydraulic pump
01/10/2010 3:28 AM
The pistons are arranged in parallel with each other in a circular array. The bottom of each piston terminates with a ball. The balls are gripped by sockets in a rotating "swash plate." This plate can be tilted at various angles; if perpendicular to the axis, no piston movement occurs. If tilted, the swash plate precesses (wobbles), driving the pistons back and forth. Thus this is a variable-displacement pump, which can maintain a steady pressure under wide range of flow, such as in a system with various loads running or not running, or running at varying speeds.
One manufacturer is Sperry-Vickers, and you might be able to find some Website pictures.
01/10/2010 10:51 PM
thank you - Steve
01/10/2010 12:00 PM
From:www.animatedsoftware.com/pumpglos/swashpla.htm
(This is a 12-frame animation, converted to animated GIF format for Internet use and transmission. (Note: On some Internet browsers it may be displayed much less smoothly than the CD-ROM version, where the frames are timed to a thousandth of a second.))
Swash Plate
(This may be a low-resolution and jerky animation of a pump which is smoothly animated in the CD-ROM version of this glossary.)
Wobble Plate
01/11/2010 7:03 AM
Good illustration.............however, the pump shown is not a variable delivery pump, it is a fixed delivery pump...........and I believe the user specifically requested a variable delivery pump.............the angle of the swash plate does not change.
This is a variable delivery pump
The swash plate angle can be altered to give variable flow.........from the position where the swash plate is now, the angle can be altered between its angle now and the vertical position. The closer the angle approaches the vertical, the flow rate reduces.........when the swash plate reaches the vertical position we have no flow (no piston movement).
In many pumps the swash plate can be moved to maximum angle, opposite to that shown. The inlet and outlet ports change to their opposites (the inlet port becomes the outlet port), thereby causing a reverse direction of flow of oil, with the pump running in the same direction.
The change in swash plate movement can be controlled by any number of means, e.g. mechanically, hydraulically, electronically....or combination of means.
.........and , or course the pump action is the same as shown by lynlynch.
01/11/2010 9:12 AM
You are correct. Now, hopefully, the student will grasp the concept firmly.
But, it's a shame your pump doesn't move.
Now, Guest, let's here from you.
01/11/2010 9:23 AM
......but, I did say it woks the same as your very good animated illustration, irrespective of pumping rate.
Sorry my illustration didn't move.
01/11/2010 9:46 AM
Sorry! I forgot
01/11/2010 9:39 AM
http://www.pumpschool.com/
01/11/2010 9:48 AM
Hi ferquiza,
Excellent pump primer. But, I see no reference to either a wobble plate or swash plate pump here. Did I miss it?
01/11/2010 9:57 AM
No, just somebodie gave this reference in some old thread and i saved it because is very nice to me so then i thought the poster could like it same than me being he is studing principles pumps wright now or i think so.-
Anonymous Poster (1); ferquiza (2); lyn (3); MOBI (3); Tornado (1)
You might be interested in: Hydraulic Pumps, Hydraulic Repair Services
