Previous in Forum: BTUs of Hydraulic Fluid   Next in Forum: Bubbles in Paint on DM Storage Tank Wall
8 comments
Salts coming out of solution at low temperature
01/08/2010 7:05 PM
Hello,
Does anyone know of tables/calculation to estimate the change in concentration of a salt solution with temperature? I am primarily interested in a caesium formate salt solution at a concentration of 2% w/w in water at 20 deg C. I would like to know the estimated concentration at 0, -5 , -10 deg C respectively.
All inputs welcome.
Thanking you in advance for your help.
Re: Salts coming out of solution at low temperature
01/09/2010 12:05 AM
http://www.formatebrines.com/tabid/237/Default.aspx
This, or the company (Cabot Specialty Fluids Ltd), might have good info.
01/10/2010 12:31 PM
Won't the solutions be frozen at -5 C and -10 C?
Dangerous Bill
01/10/2010 12:50 PM
It depends on the brine characteristics. For instance, eutectic NaCl brine remains liquid down to -6°F ≈ -21.1°C.
01/10/2010 4:28 PM
Yes, but a 2% solution?
DB
01/10/2010 5:09 PM
That could well be right. I'm not familiar with cesium formate brines, but that low a % probably would not furnish much protection against freezing, or even precipitation of the salt. Good point and GA. Welcome to CR4, btw!
01/10/2010 5:52 PM
Thanks for your comments guys, I am wondering what the concentration would be like at just above the freezing point. Where the liquid would be thicker but still liquid, and that portion of liquid that is flowing would be more concentrated. I am wondering if the water freezes first at 0 deg C and some of the salt is expelled from the solution making the unfrozen portion of solution stronger in concentration.
01/10/2010 5:58 PM
01/11/2010 2:20 PM
Hi staggersandfalls,
Temperature does not change the physical composition of solutions. It changes ONLY if solute falls out of solution. Since you are working with a 2% solution, well below the solubility limit at 0ºC, I doubt that you would see anything fall out, even at -5ºC. (but you might be frozen at that point anyway).
Below are the solubility limits for cesium formate at various temps. (WIKI Solubility Tables)
Temp Sol. (g/100g H2O)
0°C 335
10°C 381
20°C 450
30°C 694
At 2%, you have 2 grams CsHCO2 in 100g of solution; the most you can have in solution at 0ºC is 335g CsHCO2 in 435g of solution. That's 77%.
Since you have a solution, the freezing point would be somewhat depressed. As said previously, probably not much. At the point where you have 2 phases; liquid and solid; it is conceivable that the phases could have different concentrations of the salt.
Mike
Register to Reply 8 comments
Mikerho (1); staggersandfalls (2); Tornado (3); wpenrose (2)
